2017 R2 SDK Release Date
Hi, do you have a release date fro the R2 version of the SDK? Also, would it be possible to post the release notes for the upcoming version?
8th of June.
I know that reseller’s or distributor’s portals have been filled with pre-release information for approximately 8 weeks. Make sure to sign-in using your MyMilestone to check it out. If you do not have a partnership like that with Milestone the information will be available at release. The information is centered around the XProtect VMS and I have to admit that I am not sure what is included of information on the upcoming MIP SDK in the pre-release announcements.
All will be revealed on the 8th of June.
