I would appreciate if you could give us more information About MIPSDK “EnvironmentManager.Instance.TraceFunctionCalls”
1. Even if “true” is set, whether or not it outputs a debug log changes as follows.
PREREQUISITE: An application that uses ImageViewerControl and PlaybackUserControl to play back real-time and past footage of the camera.
A) When it is displaying real-time video in “ClientLive” mode
→ it doesn’t output debug log
B) When the past video is played in “ClientPlayback”
→ it outputs the following two lines of debug log repeatedly
Debug: PostMessage():SmartClient.PlaybackCurrentTimeIndication to PlaybackUserControlMini.TimeChangedHandler
Debug: PostMessage():SmartClient.PlaybackCurrentTimeIndication to (Returned)PlaybackUserControlMini.TimeChangedHandler
What is the condition for outputting the above debug log?
2. Is it possible to temporarily stop debug log output during application is running and value is set to “true”
(Can you externally override it to false?)
3. Is it possible to set automatic deletion and maximum size of the output log?
