Hi community,
I’m newbie! I searched the forum but it seems that this case is quite unique. I am looking for a minimal working example to export/download some files within a time interval from Linux machine and process them locally. Any language is OK, but it has to run on the Linux machine. The remote machine may have any operating system. Any idea??
I have an idea that what you ask is most effectively achieved for you if you look into the Mobile SDK. It will require that Mobile Server is setup and used, but it will greatly enhance the abilities as it directly supports that you can ask for a export to be made server side and the resulting files downloaded.
The recommendation is to create an export is by using investigation functionality which includes :
Please have a look into it - https://doc.developer.milestonesys.com/mipsdkmobile/
