Accessing RTSP urls from Media Streaming API
I am interested in the new XProtect RESTful API. I was able to acquire access token and list connected cameras.
Currently, I am trying to consume the Media Streaming API and obtain RTSP urls as per the OpenAPI Specification attached below
openapi.txt (19.7 KB)
But there is no documentation regarding where this service is hosted or how to set it up. Please note that this API has nothing to do with XProtect Open Network Bridge.
Best regards,
Eslam
For now please use the (pilot) categories created for XProtect App Platform. (XProtect App Platform is right now in a beta stage and only available to invited pilot partners, we expect this to be changed but for now please use the specific categories for XProtect App Platform. When you have this API I must assume you are a pilot partner.)
See the same question asked here: Access RTSP stream link via the Media Streaming API
Thank you for your response, you guessed correctly.
Can you tell me where I might find these (pilot) categories for XProtect App Platform?
In the left hand side of the forum expand Categories.
If you do not see the XProtect App Platform category please use this recipe:
For any questions related to the XProtect App Platform, please use the Pilot Partner dedicated group on the Developer Forum.
To access the group:
Log in or register on the Developer Forum.
In the left-hand panel, click “More” and then select “Groups.”
Find the private group called “XProtect App Platform (Pilot Partners only)”, click on it, and request access.
Access is generally provided within one business day..
When you have access, then in the left hand side under Categories, you can choose ‘All categories’ and now you will see new categories: XProtect App Platform, App Builder, App Center & XProtect App Platform, Dev Portal Announcements.
