Hi Rie Kito, keep testing the application and notice some behaviors, I describe them below hoping they help determine what happens
1.-When I test the AlarmEventViewer program locally, it works, when invoking it remotely I get this error
Exception
loading Event ()
An unsecured or incorrectly secured fault was received from the other party. See the inner FaultException for the fault code and detail.
Server stack trace:
at System.ServiceModel.Channels.SecurityChannelFactory`1.SecurityRequestChannel.ProcessReply (Message reply, SecurityProtocolCorrelationState correlationState, TimeSpan timeout)
at System.ServiceModel.Channels.SecurityChannelFactory`1.SecurityRequestChannel.Request (Message message, TimeSpan timeout)
at System.ServiceModel.Dispatcher.RequestChannelBinder.Request (Message message, TimeSpan timeout)
at System.ServiceModel.Channels.ServiceChannel.Call (String action, Boolean oneway, ProxyOperationRuntime operation, Object [] ins, Object [] outs, TimeSpan timeout)
at System.ServiceModel.Channels.ServiceChannelProxy.InvokeService (IMethodCallMessage methodCall, ProxyOperationRuntime operation)
at System.ServiceModel.Channels.ServiceChannelProxy.Invoke (IMessage message)
Exception rethrown at [0]:
at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage (IMessage reqMsg, IMessage retMsg)
at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke (MessageData & msgData, Int32 type)
at IAlarmCommand.GetEventLines (Int32 from, Int32 maxCount, EventFilter filter)
at VideoOS.Platform.Proxy.AlarmClient.AlarmClientCredentials.GetEventLines (Int32 from, Int32 maxCount, EventFilter filter)
at AlarmEventViewer.MainForm.loadClientEvent () in C: \ Program Files \ Milestone \ MIPSDK \ ComponentSamples \ AlarmEventViewer \ MainForm.cs: line 210
okay
2.- I was also testing the AnalyticsEventViaLibrary example remotely and the example works, since it retrieves the information from the camera that I have connected to the Milestone environment, when pressing the “Send Analytics event” button, the event is not visible in “Xprotect smart client 2021 +”, I was analyzing the packets over the network and I realized that when I pressed the button, the server threw an error code 500, I attached a picture file, when tested locally it works correctly
Are the sample programs made to work locally? Could they work on the network?
regards
