Anybody using Milestone?
I’m building a network consisting of many cameras across many locations. I need them all to be recorded, all the time. I’m not sure if Milestone does this, or only motion. I have it installed and I cant tell. I’m also unsure of what kind of hardware I am going to need.
Default is record on motion but you can setup that you want record always..
As this does not pertain to development but to a general situation you will most likely get better help from the partners active in the Support Community - https://supportcommunity.milestonesys.com
