Is it possible to get video via a API command of a mobile server? I would like a command to get a full stream and the command to get a reduced (lower frame rate and/ or lower resolution) video. Is this possible?
KR
Shaam
KR
Shaam
The SDK for Mobile Server is described here. https://doc.developer.milestonesys.com/mipsdkmobile/
If this is not what you seek you can maybe elaborate on your question.
