API XPMobileSDK Web. Streaming video for a specified period of time. Not live stream
Is it possible to view a video in a stream by specifying a time period without downloading it (without using the XPMobileSDK.library.Connection.startVideoExport method). Thank you.
Hello Leonid,
I can help you better if I knew more context but in general yes you can as long as there are recording of the time span you want to play. You can use command RequestStream (https://doc.developer.milestonesys.com/mipsdkmobile/reference/WebSDKdoc/global.html#RequestStream) and give as parameters
SignalType: “Playback”
SeekTime: “Time”
Time: “THE TIME YOU WANT IN MILISECONDS SENSE EPOCH”
The details of the command in a protocol level can be found here: https://doc.developer.milestonesys.com/mipsdkmobile/reference/protocols/mobile_command.html#command_RequestAudioStream
I hope that help.
/Teodor
Thank you!!! it works!
