If you want to do it online (connected to the running XProtect VMS running) then unfortunately no, there is no way.
If offline, using files copied out of the XProtect VMS, you can load the files offline. The Media Playback Viewer sample might be the best sample for you as it can load offline and it shows a “timeline” which might be a valuable hint for how to find the first and last image time.
