there is a plugin for Arecont 180 °? I would to view 1 image only.
Christian
Christian
No, there are no specific plugins for the Arecont Vision devices, and neither should this be necessary. In the Management software, you can select the lens type being used for this device, and this should enable the Smart Client to de-warp the view.
Thank Michael. How I can to find lens type? I have 360 lens tab only.
This is usually found on the lens or camera body. If you mean panomorph/Immervision support, you should have the 3 supported lens types to choose from in the drop-down list.
Are not panomorph, simply 180°. However Thanks a lot
Christian
