Looking at the following article I’m wondering if it needs to be updated:
https://developer.milestonesys.com/s/article/Optimize-AD-active-directory-users-logins
We’re told to rename the file to LoginOptimizationParameters.xml but then told to rename it again to login_optimization_parameters.xml.
Also in step 2 we’re told we can use recursive level=# to change subgroup lookup behavior, however in step 4 we’re told we can setup group indexing without any real clear guideline on how to actually do that.
Is there missing information in that article?
