Hello I’m using exoplayer to reproduce Live Audio from the Camera but I can´t listen the live audio from the camera. I would like know if the URL setting is correct. I have attached the code.
Regards
Darío
Regards
Darío
The URL format is correct.
Note that to be able to use the URL, you need to call requestAudioStream first, using AudioEncoding = Mp3 input parameter.
Best regards,
Plamen Parvanov
