Hello
I’m using that code to pick camera
private void button1_Click(object sender, EventArgs e)
// properly discard the previous camera control, if one is already selected
if (imageViewerControl != null)
imageViewerControl.Disconnect();
imageViewerControl.Close();
imageViewerControl.Dispose();
imageViewerControl = null;
ItemPickerForm picker = new ItemPickerForm();
picker.TopMost=true;
picker.KindFilter = Kind.Camera;
picker.Init(Configuration.Instance.GetItems());
if (picker.ShowDialog() == DialogResult.OK)
selectedItem = picker.SelectedItem;
label2.Text = [selectedItem.Name](https://selectedItem.Name);
try
// image viewer control settings
imageViewerControl = ClientControl.Instance.GenerateImageViewerControl();
imageViewerControl.Dock = DockStyle.Fill;
panel1.Controls.Clear();
panel1.Controls.Add(imageViewerControl);
imageViewerControl.CameraFQID = selectedItem.FQID;
imageViewerControl.EnableDigitalZoom = true;
imageViewerControl.EnableVisibleHeader = false;
imageViewerControl.Initialize();
imageViewerControl.Connect();
catch (Exception ex)
now i know that i want to view exacly 1 camera and put in program c# automaticly pick up camera name “Camera 1” for example
it is posible to do that?
