AXIS P12 Mk II is Main Unit
Understood AXIS P12 Mk II is Main Unit has not been supported by DP even v 8.8
One of APAC customers are looking for any update for the support, thank you.
The Axis P12 series is certainly supported, including P1204, P1214, P1214E and P1224 for both XProtect Professional VMS and Advanced VMS, as noted in the Supported Hardware list: https://www.milestonesys.com/solution-partners/supported-hardware/other-xprotect-products/?dp=77&m=7
Thank you Michael, understood that P12 MK II is to be used with cameras such as P1204, P1214, P1214E and P1224, I will update customer accordingly.
