Through browser, We need to pull the video feed from Milestone.
Is there a better way except Milestone web-client to achieve this?
Thanks,
4W Team.
Thanks,
4W Team.
The Mobile Server will give you JPEGs which are useful in browser, this is what the web-client use. It would be possible to make your own alternative to the Mobile Server which could serve your implementation of a web client.
I am curious, what would be better? What do you see as the ideal way?
While login in Milestone Web Client for each video view it takes 4 to 5 sec. We are having another application that pulls JPEG images from Milestone Corporate and telemetry data(another application). We need to reduce the login time. How to achieve this?
4W Team
The login time will be expected to be the same in Smart Client, Web client and clients based on the MIP SDK. To get some ideas on troubleshooting or optimizing login scenarios please try to ask the Support Community.. https://force.milestonesys.com/support/MccSupportCommunity
Sometimes the answer is to stay connected and avoid unnecessary re-login. (Might or might not be useful advise.)
Thanks Andersen
