Camera's coordinates
Is there any API that publishes the camera’s coordinates used on the map application?
I’m building a solution to a customer and I’d like to avoid him to keep two separated databases for this information.
If you by “map application” mean the old Map plugin in the Smart Client the answer is unfortunately no. However, if you mean the Smart Map plugin in the Smart Client, you can indeed read the coordinates through the SDK and APIs. E.g. using the Configuration API: https://doc.developer.milestonesys.com/html/index.html?base=gettingstarted/intro_configurationapi.html&tree=tree_4.html
