Can Analytics Event XML (Protocol Integration) also be sent with HTTPS?
Hello!
https://doc.developer.milestonesys.com/html/reference/protocols/analytics_and_mad_events.html does not mention HTTPS and the screenshot shows only one port to configure, so I fear the answer might be NO.
If it is not possible, is there any way to transmit analytic events with HTTPS and protocol integration?
(Protocol integration would be necessary on embedded devices where MIP .NET Library is not available.)
Thank you for your time!
Best regards,
Jürgen Werner
For now you can only use Http.
That’s a pity.
Thanks for letting us know.
