In the XProtect Management Client, I build my configuration tree and UI using ItemManager.
When right-clicking a tree node, the context menu only appears to support three fixed commands: ADD, DELETE, and RENAME (confirmed via ItemManager.IsContextMenuValid).
Is there an SDK-supported way to add custom context menu items to a tree node, beyond these three built-in commands?
Yes. Besides the standard Add/Delete/Rename operations, you can define custom context-menu entries for items in the Management Client.
Take a look at VideoOS.Platform.Admin.ContextMenuItem. It is intended for context-menu entries in the Administration clients and is defined by the ItemManager that owns the item type.
