Can exported recordings be played back in a stand-alone dvd player
XProtect Corp 2016R3.
I’ve exported recordings using a variety of settings and none of them play in dvd players that I’ve tried.
Do you recommend particular export settings and make/model of dvd player?
Thankyou.
The export is data which can be stored in a DVD. It is not creating a movie which will play in a regular DVD player. Even with MKV export which would probably be the same format it does not simply playback in a DVD player.
For questions not related to development of integrations please use the support community.. https://force.milestonesys.com/support/MccSupportCommunity
