It is a clear recommandation that you use the newest MIP SDK when developing. This is why Milestone does not maintain a list of old download links.
If you have a special case and a special reason there might be ways, let me know what you have..
We are having the same issue here.
Our customer has a XProtect Corporate 2014 installation so we thought that the best option to be compatible with it was to use the same SDK
version.
David, that is not the recommendation. Please use the newest MIP SDK.
Bo,
Thanks for your reply. My customers are running multiple (older) versions of the Management Server. I’ll try and get a list of which versions we’re actually using, but I believe they are from late 2016 or early 2017. My past experience has been that if the SDK I’m using is newer than the Management Server, I experience problems, hence my request for an older version of the SDK.
Thanks,
Mark
I am sorry that is your past experience. Especially with customers at different versions I strongly suggest you use the newest MIP SDK as a common ground, and if you experience an issue tell Milestone about it.
I will provide a link to an old version if you have reasons to request it, but be precise when requesting it, and know that if you experience an issue Milestone Support will ask you to upgrade so that we can troubleshoot and debug with the newest version of the MIP SDK.
