Good evening. I see that events (I’m most interested in analytics event) and alarms can be stored in the Event Server for a certain amount of time that can be set through the management interface. I would like to edit some fields of the analytic event while keeping it in the Event Server as, for example, the Description field of the event could change based on the actions of a Client (e.g. he presses some buttons) or from an external Alanytics Server. Is it possible to achieve this with Protocol Integration? If yes, how?
