Can I get high quality AAC audio from an AXIS P8221 on Milestone XProtect Expert 2017 R3 and up?
Hi
I’m currently using an older version of XProtect Expert that can only get G.711 quality of audio from the AXIS I/O audio module.
Before I upgrade I wanna make sure AAC is now supported with this combination.
Oren
