can I install my plugin into Husky?
I developed a plugin by using MIP, can I install my plugin into Husky? If I can do that, can you give any operate guide?
The Husky 10 is different and does not have an Event Server and Management Apllication is replaced by another interface, so plugins to those environments will not work. With other Husky versions it should work..
