Can the TcpVideoViewer sample be modified to retrieve the masked live camera stream from milestone?
I am using the TcpVideoViewer to retrieve live feed from milestone and broadcast it as motion jpeg url.
This integration is working as suspected but when the camera has masking , I get the lock image attached .
My goal is to retrieve the masked live stream from the camera.
I modified the FormatConnect
method to the below:
private string FormatConnect()
            string sendBuffer;
            if (_token == "BASIC")
                sendBuffer = string.Format(
                    "<?xml version=\"1.0\" encoding=\"utf-8\"?><methodcall><requestid>0</requestid>" +
                    "<methodname>connect</methodname><username>{0}</username><password>{1}</password>" +
                    "<cameraid>{2}</cameraid><alwaysstdjpeg>yes</alwaysstdjpeg>" +
                    "<clientcapabilities>" +
                    "<privacymask>yes</privacymask>" +
                    "<privacymaskversion>1</privacymaskversion>" +
                    "<multipartdata>no</multipartdata >" +
                    "<datarestriction>yes</datarestriction >" +
                    "</clientcapabilities>" +
                    "</methodcall>\r\n\r\n",
                    XmlEscapeGt127(_user), XmlEscapeGt127(_pwd), _cameraGuid);
            else
                    "<methodname>connect</methodname><username>gaby</username><password>g</password>" +
                    "<cameraid>{0}</cameraid><alwaysstdjpeg>yes</alwaysstdjpeg>" +
                   "<transcode><allframes>yes</allframes></transcode>" + // Add this line to get all frames in a GOP transcoded
                    "<connectparam>id={1}&amp;connectiontoken={2}" +
                    "</connectparam>"+
                    _cameraGuid, _cameraGuid, _token);
            return sendBuffer;
according to the bellow url
https://doc.developer.milestonesys.com/html/reference/protocols/imageserver_request_response.html
now I can see the live stream but without the masking.
Can the TcpVideoViewer be modifed in any way to make this possible ?
Best regards,’
Gaby
I need a clarification please. After having modified the FormatConnect do you still get padlock images or do you get correct images but without any masking?
Hello Bo,
I got the correct image but without masking, but never mind I switched to the Media Live viewer sample and I go the needed functionality .
Thank you
I am glad to hear that you now have a solution.
There is currently no plan to extend the TCP Video Viewer sample on the needed masking to support privacy masking, but I will make a note to the Milestone Product Management so that it can be considered for future development work.
