Can we get LPR reports in any other format ?
We have a customer running a Transport management system and is keen to integrate LPR into their application. Is there a way for us to send LPR plate details in BOF2 protocol or XML files?
Use case:
As and when the LPR system detects the plates, they want this detail to be sent to another system or folder in the above formats so their system can process the details from there.
Srini
Please explore Alarm and Event Viewer sample –
https://doc.developer.milestonesys.com/html/index.html?base=samples/alarmviewer_sample.html&tree=tree_2.html
The sample will read historical LPR Events at start up and will subscribe to and see LPR Events as they happen. You can use this to get the data and then pass it on in the format you need.
This is a standalone sample which you can use as inspiration for a service or application, same code could also be used to develop an Event Server plugin.
