Change Configs From API Functions SDK
Just I want to ask if we can change some configs of a camera in the server through the SDK API, The config functions are:-
1- Recording fps example 25 to 30
2- Recording rules, on cameras: database disk unavailable (HW)
3- Recording rules, on nvr: database repair
Can we change these configurations from the SDK api
This is possible.
Please explore the Configuration API Client sample. https://doc.developer.milestonesys.com/html/index.html?base=samples/configapiclient.html&tree=tree_2.html
When you run the sample, please unfold Recording Server - Hardware - - Cameras - and click Settings tab. You will see the settings of the camera including FPS setting and you can also change it.
2+3.
The Configuration API does unfortunately not support configuration of rules. Good news for you; Milestone is now working on the Configuration API, so the support for rule configuration will be in 2020 R1 or 2020 R2.
Disclaimer: This is planned new functionality of future MIP SDK versions. This plan is subject to change without notice.
Ok Thank You very much.
