Yes correct
Forgive me, I can read this this in two ways:
Yes, this is what we do and now it works for us.
Yes, this is what we do, but we have an issue that the GetItemConfigurations still returns the old data when the ConfigurationChangedIndication has happened and when we are working with the hotfix in Smart Client.
Which is it?
Can you provide a project or plugin that I can test with your kind of plugin and test / debug with your implementation code? Maybe you do not need to show me your solution but could show me a minimal project that would enable me to reproduce..
If I could reproduce the issue it would be easier, right now we are a bit in the dark..
@Bo Ellegård Andersen (Milestone Systems)
With the hotfix, if we do any configuration change within the first 1 minute of starting smartclient we are not getting Configuration Changed event, only getting after 1 min
Hi Thejaswi,
This is by design: the system uses 1 minute delay to accumulate more possible changes before sending the event.
