connection refused. reason: unknown device
After system restart 14 of 62 cameras have no video but each camera’s web ui has video.
Not knowing what kind of installation you have or what XProtect version, neither a camera model, it is a but hard to give advice.
What you could try: Run a hardware replacement and see if you can get the missing cameras back. Try on a single cam first. If it fails, pls contact Milestone Technical Support (through your Milestone partner).
