Controlling output of camera with onscreen button
I have a generic ONVIF PTZ camera with an output that will control a light. The output works fine from the Configuration Manager, but how do I actually use this from SmartClient? The ‘Aux’ commands seem to be something which needs to be supported directly by a specific driver, is it possible to link this to Output?
Right now I have to listen to a nonsensical event such as ‘Start Recording’ to activate and deactivate the light. I’ve made plugins for buttons that do other things in the past, but do I have to make a plugin for this as well or can it be handled from within the system?
Yes, it is possible to link overlay button to outputs. We tested it on 2022 R3 and it works fine.
If you have further questions, as this is not related to software development with the MIP SDK, which is the focus of this forum, please ask again in the support community, you should get better help from the partners using the support community.
