Couldn't LogIn to server using LogInDotNetSOAP sample
I am trying to LogIn to the management server 2025R3 version using LogInDotNetSOAP sample. I am using windows authentication, server is in remote machine and http.
Is there anything wrong in my input details?
Is that sample supports for remote windows authentication and http?
Thanks in advance!
Regards,
Priyanka Koneti
Yes. Enter the username without putting the domain in front. (NOT domain\user, but only user)
If XProtect is setup to use encryption, then you must must enter the address like this “10.10.68.21:443” (HTTPS), and answer yes to encryption.
If XProtect is setup to use encryption, then you must must enter the address like this “10.10.68.21:80” (HTTP), and answer no to encryption.
Ports can be changed, these are default ports.
If you can login using the Smart Client you know you have a correct server address, port and credentials, so if you still cannot connect please test.
Thank you for the quick response. The sample is working fine.
Now I come to my real issue. We are using SOAP service from RADStudio to connect to the management server and ServerAPI/ServerCommandService.asmx endpoint. It was working fine until 2025R1 versions. we couldn’t make it work for new versions.
I have replaced the endpoint url from ServerAPI/ServerCommandService.asmx to ManagementServer/ServerCommandService.svc and tested with 2025R1 version, it is showing “HTTP/1.1 415 Cannot process the message because the content type ‘text/xml; charset=utf-8’ was not the expected type ‘application/soap+xml; charset=utf-8’.\r\n” error in Wireshark.
When I check the Wireshark with ServerAPI/ServerCommandService.asmx endpoint, it doesn’t have any NTLMSSP process. please refer the following image
Do i need to change any severside configuration?
How do I resolve this issue?
Regards,
Priyanka Koneti
ServerCommandService.asmx does not exist in newer versions.
ManagementServer/ServerCommandServiceOAuth.svc is now the recommended service.
I hope you will be able to use it based on the sample and the documentation.
