when I add 3-5 cameras by driverframework, the CPU usage is almost 100% all the time。Video resolution is 2560*1440,bitrate is 4096,Type is h265, The driverframework process is about 30% ,recordingservice is about 55%.
Also I tried the DemoDriver ,when I add 8-10 simulated devices,the CPU usage
will reach 100%。
Compare with onvif (10 cameras , 60% CPU usage), the CPU usage is too high.
The cpu is Inter Core i5 6500. I closed the Motion and set always record.
MIP SDK version is 2022R1,XProtect version is 2022R2.
Is there any performance data or require with Driverframework?
I tried the newest MIP SDK , version is 2022R1 and the newst XProtect, verstion is 2022R2. But the CPU usage seems to be the same as 2020R1. Their CPU usage will all reach 100% with 3-5 cameras.
