Creating Multiple Bounding Box
Hi ,
Can we create multiple bounding box for single metadata?
Now, it is creating single bounding box using onvif object.
Thanks,
BHI Team
In effect the Bounding Box submitted is a chunk of XML. If you modify the sample so that it includes multiple bounding boxes it will work. Unformatunatley the sample does only show one box, but i hope this hint is enough that you can make it woork with multiple boxes.
Thanks we will try the same.
We created multiple onvif object but it is showing only last created object value. How to show both the onvif object data in camera. How to do it.
A clarification:
If you send a matadata chunk and then another the Smart Client will show the newest, only one at a time.
If you send metadata with two bounding boxes within they should display both.
Are you sending two boxes in one?
