data in smart client
hi,
i retrieve data like humidity, temperature via mqtt from a lora gateway
how can i show these data in smart client and generate alarm/event?
the gateway cannot be added as a hardware device in management client.
Thank you
There are two ways I want to mention to submit data into XProtect; metadata and analytics events.
Compare the two here: https://developer.milestonesys.com/s/article/DATA-FROM-ANALYTICS-HOW-TO-BEST-IMPLEMENT-A-SOLUTION
From what I gather I do not think the data is high frequency and it is probably analytics events you need.
Two samples than can be used to submit analytics events..
https://doc.developer.milestonesys.com/html/index.html?base=samples/protocolsamples/triggeranalyticseventxml/readme.html&tree=tree_3.html
https://doc.developer.milestonesys.com/html/index.html?base=samples/protocolsamples/eventsrestapipython/readme.html&tree=tree_3.html
