Device to change depending on route direction
Apologies if I’ve labelled this wrong under “events”.
I have a concept. Imagine there is a car and it is moving from camera A to camera B and you know camera B is going to be next along that route. based on the last camera used “streamed” in Smart Client is there a way in which I would know pressing a switch would put me to the next camera along that route.
Is this something I would look into for the API or is there already something like this that exists under event based on camera location.
Thank you.
There is nothing that fits in Milestone XProtect. You could create a Management Client plugin where you could setup Camera A “camera to follow” = Camera B. You could then create Smart Client plugin, a camera toolbar button, that when used under Camera A will replace the current camera with Camera B, or display Camera B somewhere else. You should use your imagination on how to do this best. There is of course a lot of room for creative thinking here. Some samples that might inspire.
https://doc.developer.milestonesys.com/html/index.html?base=samples/pluginsamples/serversidecarrousel/readme.html&tree=tree_1.html
https://doc.developer.milestonesys.com/html/index.html?base=samples/pluginsamples/sctoolbarplugin/readme.html&tree=tree_1.html
https://doc.developer.milestonesys.com/html/index.html?base=samples/pluginsamples/schotspot/readme.html&tree=tree_1.html
You are welcome to run ideas by us if you get closer to the actual way you want this to work.
