Does the configuration prameter "Max frames between keyframes" in Milestone equivalent to the device's parameter "I Frame Interval"?
When I add a Generic Hikvision IPC to Milestone, I found the value of the “Max frames between keyframes” is 125 and I can’t find any prameters is 125 in Camera’s web configuration page. At the same time, the value of the camera’s prameter “I frame Interval” is 20.
So I want to know which parameter of the M platform corresponds to this parameter "I frame Interval"of the camera? And which parameter of the camera corresponds to this “Max frames between keyframes” in Milestone.
As we know, HikGeneric driver is based on the ISAPI protocol from Hikvision. I sumit two pictures, it display the “I frame Interval” corresponding fields in the protocol.
Thanks very much.
As this question is about the VMS configuration please ask it on the support forum instead: https://supportcommunity.milestonesys.com/s/?language=en_US
The developer forum is intended to be used for questions directly related to development.
Best regards,
Peter
