Hello, I need to dokerize a rest api, after installing the api, in addition to the project library, it does not work on the machine, is it necessary to install some package, 2023 R2? Greetings.
We do not currently have support for running the Milestone in a docker environment. But you should be able to run parts of milestone in an docker environment.
Could you elaborate a bit on what you mean by “does not work”, Which errors are you getting?
