Support for alarms has been added on the Smart Map. It is also possible to use Smart Map in the alarm
manager. Each alarm can be configured individually to use Smart Map or Maps in the Alarm definition.
We have also Increased the usability of Smart Maps in setup mode. It is now possible drag and drop
multiple devices at the same time onto the map. It is also possible to delete devices directly on the
smart map in setup mode.
Regarding to above VMS products 2020 R2 release notes
Now, can we add device icons on smartclient map or smartmap through MIP SDK instead of via element selector manually?
Now, can we have multi color for these icons to reflect different alarm and event received?
If yes, please share the samples we can look through. Thank you.
