Edit Login Smart Client 2019 R3
Is there any way to edit that can be selected from the Milesone 2019 R3 login.
I wish that you could only log in to the Smart Client with the WindowsDefault, if I set the autologin the cancel button still appears, allowing other users to be logged in to log in.
There is no functionality in the Smart Client to customize the login dialog the way you describe.
