eLearning MIP SDK
I wonder if there are new Milestone Solution Partners in this forum who used the eLearning- "Getting Started with the MIP SDK " and “Developing MIP SDK Component Integrations” to get a first introduction into the MIP SDK?
Any thoughts or recommendations you can share?
Regarding the location of the SDK eLearning, I’ll give you three links:
  1. The category, under which all SDK eLearning should be found, now and in the future: https://go.bluevolt.com/Milestone/Catalog/Developing-with-the-MIP-SDK/21043/
  2. Getting Started with the MIP SDK: https://go.bluevolt.com/Milestone/CourseDetail/Getting-Started-with-the-MIP-SDK/89591
  3. Developing MIP SDK Component Integrations: https://go.bluevolt.com/Milestone/CourseDetail/Developing-MIP-SDK-Component-Integrations/97017
These courses will require you to login using your My Milestone account. (Anyone who has downloaded the SDK, asked questions or posted answers on this developer forum will have a MyMilestone account.)
Thank you very much for the links you provided. But your first link isn’t working, i would have never been able to find the two other ones, can you list the other courses concerning the MIP SDK since i cannot find them elsewhere.
Thank you again !
It works for me after going through the login and the finding the link again (isn’t remembered while I do the login).
There is currently the two mentioned eLearning classes on MIP SDK, so even if you do not see the list you can see all the courses on the direct links.
