Empty AlarmDefinition fetching...
Hello.
I have to fetch AlarmDefinition list and I have tried with SDK example in the post https://developer.milestonesys.com/s/question/0D50O00005DTE9sSAH/get-alarmdefinition-list-with-getitemsbykindmethodkind-is-not-possible but, for me, AlarmDefinition list is empty. Really I have to fetch AlarmDefinition in my custom EventServer plugin…for Plugin integration is the same or exist some other technique ? Thanks.
You should use basically the same approach as described in the post you are referring to. Of course you don’t need to log in if you are running in a plugin.
