End call for XPMobileSDK.RequestStream after a while
Hi guys.
Is there a way to end (or to generate an error ) on the XPMobileSDK.RequestStream , after a period of time ?
The scenario is the following: on my app , a message “Start loading” remains forever. The reason is that the call to Request stream never respond with an error or with a succesful connection.
So, I want to terminate the call to requeststream after one minute or so.
thanks for your comments.
Hello Luis,
The solution that I can propose to you is to use XPMobileSDK.requestStream instead of XPMobileSDK.RequestStream. I made a detailed video explanation what is the differences and how you can benefit from this command here:
https://youtu.be/G7FcAbOtdD0
Thanks Teodor, I really appreciate your help.
Yep, I’ll give a try on the requestStream…
Thanks again!
