Enhance camera configuration "Events" tab via MIP SDK
Hi all!
Is it possible to change or add to a pre-defined tab in the camera configuration of the Management Client via the MIP SDK?
It is not possible to change the predefined tab but you can add a new tab. There are two samples that they might be helpful.
Admin Tab
https://doc.developer.milestonesys.com/html/index.html?base=samples/pluginsamples/admintabplugin/readme.html&tree=tree_1.html
Admin Hardware Tab
https://doc.developer.milestonesys.com/html/index.html?base=samples/pluginsamples/admintabhardwareplugin/readme.html&tree=tree_1.html
Thank you, that helped a lot!
