I will use Milestone Software Manager for upgrading some video server targets(Milestone Software Manager 2023 R3 Version: 23.3a Build: 25).
My problem is the communication from MilestoneSoftwareManager to the video servers, it seems to be interrupted if the video server target system uses NAT.
below the error:
Task: Ping (Failed)
_- Last error: The object exporter specified was not found. (Exception from HRESULT: 0x80070776)_
_- Type: WMIPingTask_
_- State: Completed_
_- Result: Failed_
_- Host time: 31/12/9999 23:59:59_
what could be the solution o workaround?
thanks in advanced
