Error occured when using exportSample.
Hi.
I used the exportsample in MIP(2018R3).
the following error occurred, when exporting some cameras
Error initializing export: no video or audio stream has been specified!: DETAILED_ERROR_NO_STREAMS_TO_EXPORT(3)
would you tell me why error occurred?
When you see this error please test whether you in the Smart Client can export the camera. (Same camera, same time period, same user,)
This test will show whether there is a general issue in the XProtect VMS or an issue in the MIP SDK.
In Smart Client (Same camera, same time, same user) , it works good.
so, i tested that export to mkv format by exportsample.
it work good, too.
only error occur when exporting .avi.
What is your XProtect server product and version?
Do you have multiple cameras on which you experience this issue?
Do you see any errors or crashes on the recording server?
Hello there,
I used the exportSample in MIP and the same error occurred on my environment, too. But only a particular type of camera(Panasonic WV-S4150) has the problem.
- XProtect version is XProtect Professional+ 2018R3.
- I use devicepack10.0a.
- I can export the camera in the Smart Client.
- With MKV, the value of VideoOS.Platform.Data.IExporter.LastError is 1.
- With AVI, the value of VideoOS.Platform.Data.IExporter.LastError is 3.
- Both of RTSP(H254) and HTTP(Jpeg) have an error when the camera connecting to the XProtect recording server.
