Error when installing XProtect Professional+ on Server 2019.
9/24/2020 7:13:31 PM Error An error occurred: ‘InstallationAdapterException: Could not configure the server. See the log file for more information. —> ServerConfiguratorFailedException: Error occured while configuring the server. See log file at [C:\ProgramData\Milestone\Installer\ConfiguratorI.log](file:C:/ProgramData/Milestone/Installer/ConfiguratorI.log) for more information. —> ServerAdminException: CFG64018: Failed to configure service account ‘NT AUTHORITY\NETWORK SERVICE’ on database Surveillance. Error: Object reference not set to an instance of an object.’. Error details: at VideoOS.Installer.ServerConfiguratorPlugin.ConfigurationTaskInstall.DoRun()
at VideoOS.SoftwareManager.Core.Task.Task.Start()
9/24/2020 7:13:31 PM Error An error occurred: ‘ServerConfiguratorFailedException: Error occured while configuring the server. See log file at [C:\ProgramData\Milestone\Installer\ConfiguratorI.log](file:C:/ProgramData/Milestone/Installer/ConfiguratorI.log) for more information. —> ServerAdminException: CFG64018: Failed to configure service account ‘NT AUTHORITY\NETWORK SERVICE’ on database Surveillance. Error: Object reference not set to an instance of an object.’. Error details: at VideoOS.Installer.ServerConfiguratorPlugin.ServerConfigurator.ServerConfigure(ILog logComponent, Int32 webSitePort, String configuratorLogPath, Action registerManagementServer)
at VideoOS.Installer.ServerConfiguratorPlugin.ServerConfigurator.RunInstall(Boolean isHWMM, Boolean isFinalizedMode)
9/24/2020 7:13:31 PM Error An error occurred: ‘ServerAdminException: CFG64018: Failed to configure service account ‘NT AUTHORITY\NETWORK SERVICE’ on database Surveillance. Error: Object reference not set to an instance of an object.’. Error details: at VideoOS.Server.Admin.Utilities.DatabaseUtils.SetAdminRoleAccount(AccountInfo serviceAccount)
at VideoOS.Server.Admin.Utilities.ServerUtilities.SetAdminRoleAccount(AccountInfo serviceAccount, String databaseServer, String databaseName)
9/24/2020 7:13:31 PM Error Install failed.VideoOS.Installer.Sequencer.ErrorHandling.InstallerSequencerException: Could not configure the server. See the log file for more information. —> VideoOS.Installer.ServerConfiguratorPlugin.ServerConfiguratorFailedException: Error occured while configuring the server. See log file at [C:\ProgramData\Milestone\Installer\ConfiguratorI.log](file:C:/ProgramData/Milestone/Installer/ConfiguratorI.log) for more information. —> VideoOS.Server.Admin.ServerAdminException: CFG64018: Failed to configure service account ‘NT AUTHORITY\NETWORK SERVICE’ on database Surveillance. Error: Object reference not set to an instance of an object.
— End of inner exception stack trace —
09/24/2020 14:13:31 CFG64018: Failed to configure service account ‘NT AUTHORITY\NETWORK SERVICE’ on database Surveillance. Error: Object reference not set to an instance of an object.
09/24/2020 14:13:31 at VideoOS.Server.Admin.Utilities.DatabaseUtils.SetAdminRoleAccount(AccountInfo serviceAccount)
Is there a way to change the service account that is being used. That is what I believe the issue is.
I moved it to the support forums.
