Event message protocol. How to build a message and send it to the Event Server?
Good day.
How are you?
I want to be able to send mEvent Messages to the Event Server.
I have tried the sample AnalyticsEventTriggerViaLibrary to send an Event to Milestone and paint a boundary box to the stream.
But the methods and the construction of the message are obscured.
I would like to know how to send a message to the event server;
an Event, so that I can handle it in a PlugIn inside the XPRotect Management Client.
Is the message sent via HTTP ? Or directly using TCP/IP ?
MessageCommunication which is used in the AnalyticsEventTriggerViaLibrary is not a documented protocol and should be used with the MIP SDK classes as in the sample. If you are developing a plugin you must use the MIP SDK classes.
An alternative if you want a protocol method instead you should instead explore the TriggerAnalyticsEventXML sample. This protocol is sending XML with HTTP header using System.Net.Sockets.Socket to port 9090 of the Event Server.
I am in doubt if this answers your question, if not, please try to ask again..
MessageCommunication is TCP on port 2333 on the Event Server..
https://supportcommunity.milestonesys.com/s/article/Ports-for-alarms-from-Milestone-Event-Server-service?language=en_US
You can also send a NewEventCommand MIP message, like in mipsdk-samples-component/EventForm.cs at main · milestonesys/mipsdk-samples-component (github.com).
Also the XML in 9090 as Bo mentions: mipsdk-samples-protocol/TriggerAnalyticsEventXML at main · milestonesys/mipsdk-samples-protocol (github.com)
You can also use AddEvent from the AlarmCommand. You can see how to use the AlarmCommand in general here: mipsdk-samples-protocol/AlarmList at main · milestonesys/mipsdk-samples-protocol (github.com)
