Event server launched as exe no more runs on 2020 R1
I have an Access plugin developed with SDK 2019 R2.
I have Xprotect 2020 R1 and I can’t launch Event Server as exe anymore:
Exceptions raised:
Exception levée : ‘System.ServiceModel.FaultException`1’ dans System.ServiceModel.dll
Exception levée : ‘System.ServiceModel.FaultException`1’ dans mscorlib.dll
Exception levée : ‘System.ServiceModel.FaultException`1’ dans VideoOS.Management.VmoClient.dll
Exception levée : ‘VideoOS.Management.VmoClient.VmoException’ dans VideoOS.Management.VmoClient.dll
Exception levée : ‘System.Net.WebException’ dans System.dll
What is the problem?
Thanks.
We would like to see:
  • Event Viewer log of this crash
  • Event Server logs -[C:\ProgramData\Milestone\XProtect](file:C:/ProgramData/Milestone/XProtect) Event Server\logs -[C:\ProgramData\Milestone\XProtect](file:C:/ProgramData/Milestone/XProtect) Event Server\logs\MIPLogs
  • a dump of the Event Server in the crash
Here is the log file of the problem.
I dont’t have the dump of the Event Server in the crash.
I changed my plugin and today all seems to be OK.
I deleted the MIP Logs of the 17th April.
Sorry, I haven’t other file.
All seem to be OK but, I have already somes exceptions at launch time. I don’t know if it is normal.
I attach the trace.
I’ve just had the probleam again:
Stack trace:
> System.ServiceModel.dll!System.ServiceModel.Channels.ServiceChannel.HandleReply(System.ServiceModel.Dispatcher.ProxyOperationRuntime operation, ref System.ServiceModel.Dispatcher.ProxyRpc rpc) Inconnu
System.ServiceModel.dll!System.ServiceModel.Channels.ServiceChannel.Call(string action, bool oneway, System.ServiceModel.Dispatcher.ProxyOperationRuntime operation, object\[\] ins, object\[\] outs, System.TimeSpan timeout)   Inconnu
System.ServiceModel.dll!System.ServiceModel.Channels.ServiceChannelProxy.InvokeService(System.Runtime.Remoting.Messaging.IMethodCallMessage methodCall, System.ServiceModel.Dispatcher.ProxyOperationRuntime operation)   Inconnu
System.ServiceModel.dll!System.ServiceModel.Channels.ServiceChannelProxy.Invoke(System.Runtime.Remoting.Messaging.IMessage message)   Inconnu
mscorlib.dll!System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(ref System.Runtime.Remoting.Proxies.MessageData msgData, int type)   Inconnu
VideoOS.Management.VmoClient.dll!VideoOS.Management.VmoClient.Proxy.ServerProxy.CheckAuthentication.AnonymousMethod\_\_10\_0()   Inconnu
VideoOS.Management.VmoClient.dll!VideoOS.Management.VmoClient.Proxy.ProxyClientServiceBase<System.\_\_Canon>.CallWithRetry<System.\_\_Canon>(System.Func<System.\_\_Canon> call)   Inconnu
VideoOS.Management.VmoClient.dll!VideoOS.Management.VmoClient.Proxy.ServerProxy.CheckAuthentication()   Inconnu
VideoOS.Management.VmoClient.dll!VideoOS.Management.VmoClient.ConnectionManager.InternalConnect()   Inconnu
VideoOS.Management.VmoClient.dll!VideoOS.Management.VmoClient.ConnectionManager.Connect()   Inconnu
VideoOS.Event.Server.exe!VideoOS.Event.Server.Communication.Corporate.CorporateFeatureFetcher.FeatureReceiveThreadFunc()   Inconnu
mscorlib.dll!System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext executionContext, System.Threading.ContextCallback callback, object state, bool preserveSyncCtx)   Inconnu
mscorlib.dll!System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext executionContext, System.Threading.ContextCallback callback, object state, bool preserveSyncCtx)   Inconnu
mscorlib.dll!System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext executionContext, System.Threading.ContextCallback callback, object state)   Inconnu
mscorlib.dll!System.Threading.ThreadHelper.ThreadStart()   Inconnu
020-04-20 14:50:37 UTC+02:00 Info Log -------------------------- Version: 20.1.26.1
2020-04-20 14:50:37 UTC+02:00 Info Log Available MAC address:8C:EC:4B:13:CB:67
2020-04-20 14:50:37 UTC+02:00 Info Log Available MAC address:9C:DA:3E:D4:BF:5C
2020-04-20 14:50:37 UTC+02:00 Info Log Local time is now: 14:50:37
2020-04-20 14:50:37 UTC+02:00 Info Log UTC time is now: 12:50:37
2020-04-20 14:50:36 UTC+02:00 Info Server Event Server is starting.
2020-04-20 14:50:36 UTC+02:00 Info Server Server machine name: IJOUBERT-POR, Server domain name: IJOUBERT-POR.ALCEA2005.local
2020-04-20 14:50:37 UTC+02:00 Info Server Event Server feature manager started.
2020-04-20 14:50:39 UTC+02:00 Info FeatureManager Error opening VMO connection to: IJOUBERT-POR.ALCEA2005.local:80 with message: VMO61008: You do not have sufficient permissions to complete the operation.
2020-04-20 14:56:05 UTC+02:00 Info Log -------------------------- Version: 20.1.26.1
2020-04-20 14:56:05 UTC+02:00 Info Log Available MAC address:8C:EC:4B:13:CB:67
2020-04-20 14:56:05 UTC+02:00 Info Log Available MAC address:9C:DA:3E:D4:BF:5C
2020-04-20 14:56:05 UTC+02:00 Info Log Local time is now: 14:56:05
2020-04-20 14:56:05 UTC+02:00 Info Log UTC time is now: 12:56:05
2020-04-20 14:56:04 UTC+02:00 Info Server Event Server is starting.
2020-04-20 14:56:04 UTC+02:00 Info Server Server machine name: IJOUBERT-POR, Server domain name: IJOUBERT-POR.ALCEA2005.local
2020-04-20 14:56:06 UTC+02:00 Info Server Event Server feature manager started.
2020-04-20 14:56:08 UTC+02:00 Info FeatureManager Error opening VMO connection to: IJOUBERT-POR.ALCEA2005.local:80 with message: VMO61008: You do not have sufficient permissions to complete the operation.
I understand the problem: When I am connected to VPN, it’s OK, I can launch Event Server.
When I’m not, I have the problem.
I disconnected the VPN and :
MiGV: Configuration change: 9a1492d1-fca0-44d7-ba9c-3699c99063a7
MiGV: Configuration change: 9f6e7e9d-3fd2-49b2-9ca0-f7e7f8f8c3a7
MiGV: Configuration change: 0bb46907-c50f-46ff-8fd3-2ac454be9baf
MiGV: Configuration change: 4d2859d2-90d9-4192-afc3-3c435241af0e
MiGV: Configuration change: a4a339fd-a4a6-4da7-88c9-5d07aae61cca
Exception levée : ‘System.Net.Sockets.SocketException’ dans System.dll
Exception levée : ‘System.IO.IOException’ dans System.dll
Exception levée : ‘System.Net.WebException’ dans System.Web.Services.dll
Exception levée : ‘VideoOS.Common.CommandApi.CommandAPIInternalException’ dans VideoOS.Common.Integration.dll
La connexion sous-jacente a été fermée : Une erreur inattendue s’est produite lors de la réception.
I have la local login without active directory to log Management client.
Is it normal that debug is not allowed when computer is not connected to the company network?
Yes, I believe that debugging does require escalated privileges and which will require you to be fully trusted.
It’s a situation I hadn’t before because I was always connected to the network.
Do you think it could be corrected?
Debug can be done just with attach to process.
Maybe somebody with a greater insight into Visual Studio remote debugging would be able to guide you better. I can only say I think it has to do with rights on the remote machine, to be able to launch the Event Server as an application in debug.
I launch Visual Studio As administrator but it doesn’t solve this problem.
