Events
Eu preciso criar uma janela que funciona da seguinte maneira; quando um botão for pressionado ou qualquer evento atravé um módulo IO (ADAM) exibir uma pequena imagem à direita com a câmera, eu vi que o software tem esse recurso, mas só pode exibir uma mensagem com o alerta, como faço para exibir a imagem câmera?
Hi, please note that the support forum is only in English. Is it ok with you if you write and we answer in English?
I need to create a window that works as follows ; when a button is pressed or any event atravé an IO module ( ADAM) display a small image on the right with the camera , I saw that the software has this feature , but can only display a message with the alert, how do I display the image camera?
The Alarm Manager function of our XProtect Smart Client does exactly that. If you click on an alarm, it will show you a small image on the right with the view of the particular camera. Thus, an option you may have is to get those inputs to trigger alarms.
Another option you may want to consider is to create a Matrix, and then a new view in your Smart Client. Then create a rule in your management client that is triggered by your input module and shows the camera in the matrix window inside your smart client view.
Thanks Raul Alvaro, when use access control he displays , the mini video as described . I will perform test and then put here if everything went right .
