"Exception: Alarm Client no created: unable to find event server via registered services."What can be the cause of this error? what is the best practice solution for this?
Hi, i have a code wrriten to listen to new event coming from the server.
Randomly , i get an EX with this message:
“Exception: Alarm Client no created: unable to find event server via registered services.”
thanks.
I will need to know more about the circumstances. What is the setup and what is the code you use?
Does your code look like or build onto one of the samples in the MIP SDK? If yes, does the sample unmodified fail the same way?
