Exception from RecorderStatusService GetStatus(string token, Guid statusSessionId, int millisecondsTimeout) function
I created an application that read the events (cameras, input, … ) from all RecordingServer configured in Milestone.
I am using the following function to read all event from a RecordingServer :
where: millisecondsTimeout is set to 5000,
Get Status function returns the array of events read and so far it ran correctly in all field installations .
I installed my application in a new field with 15 Recording Servers for about 5000 total cameras. I see that i can create and start with success the session with each RecordingServer and i can read correctly the devices configurated (cameras list) but I have an exception when execute the GetStatus(…) function to read the events.
Exception received is:
[System.Web.Services.Protocols.SoapException: Error processing message
  at System.Web.Services.Protocols.SoapHttpClientProtocol.ReadResponse(SoapClientMessage message, WebResponse response, Stream responseStream, Boolean asyncCall)
  at System.Web.Services.Protocols.SoapHttpClientProtocol.Invoke(String methodName, Object[] parameters)
  at VideoOS.Platform.SDK.Proxy.Status.RecorderStatusService.GetStatus(String token, Guid statusSessionId, Int32 millisecondsTimeout)
This exception for each RecordingServer configured. Though the session is stopped and recreated I always have the exception after GetStatus() function.
The user used to connect has Basic authentication and it has role as administrator in milestone, I tried also with windows authentication but I see the same exceptions.
I tried to increase the millisecondsTimeout until 60000 but no success.
Can you help me?
If you run the StatusDemoConsole sample unmodified in your site does it work as expected or give the same exception?
I ran your example and it works correctly. Using your example, I managed to replicate the exception by inserting a delay between the session start function and the GetStatus function. I therefore understood that the exception that I reported to you is caused by the SOAP protocol timeout. I resolved this issue. Thanks so much.
